Does anyone know much about this ( I think Italian) brand.
i have a COMBI 24 which has performed ok until a new tenant moved in.
It gives hot water but will not now activate on CH
In order to start the boiler he ramped up the pressure to over nearly threee bar.
The boiler fired up and hot water suply is fine.
He says the CH came on but the pressure contiued to climb and the pressure isolation valve activated pouring hot water through the outside vent pipe. ( I assume they reopened the repressuring switches) They then switched it all off and called me to report a fault!
Now the CH wont kick in at all, and the pressure remains at sub 3bar.
Is lowering the pressure likely to help? and if so how do I do it.
Any other advice would be helpful, though I shall call in a pro if its complicated as they have a small baby and cant afford to be without heating.
Terry P
Terry P
