How dangerous would this REALLY be? There's no route to earth through the plastic pool liner. Yeah so the water could be at 100-240 volts, but they wouldn't feel it with no route to earth.
I'm studying for C&G right now and I have to say that my thoughts were the same - that theoretically at least unless there was a route to earth of course they wouldn't form part of a circuit and so no PD would exist (or I think to be more precise, they would be at equal potential to the phase conductor so no PD exists between them/ water and phase)...
Ah, OK so I had taken that to be a 2-pin un-earthed strip...
hmm.. so what happens if it was a conventional UK strip (assuming no RCD for this purpose) .. Earth is then provided for.. and they guys in the pool would then form a (albeit indirect) part of the circuit I think.
Presumably then the degree to which this is a problem (this being relative of course!) relateS directly to the the impedence of the path (water) then ? i.e. if they were standing in a freshwater lake sized swimming pool on the far side of the shore in this scenario they would be better off than being next to it in a small paddling pool of saltwater...
