Well from my last post some of you may realise removed wall paper only to find plasterboard, well I have now found the missing link.
The house was built using plasterboard, it was skimmed plastered IWO joints and screw holes, and corners remaining was left as plasterboard.
They then must have lined the wall with 800 or similar, this is what has pealed off really easily IWO plasterboard but not so much IWO plastered joints and corners, so now i have stripped all liner off except IWO platered joints and corners.
I have now primed bare plasterboard with 1:5 PVA and going to leave it until tomorrow which is when i will start to screed bad areas with filler and then feather out the remaining liners with filler, i will then sand and fill probably a couple of times? and then primes with cheap slightly diluted matt white emulsion and then two thin layers of coloured emulsion.
Do you guys think i have my work cut out?
I dont want to hang more liner done like it TBO.
Does anyone know why the existing liner came away so easily IWO bare plasterboard? DId they not prep properly?
