Looking for advice re failed earth test. Combi boiler goes dead. Gas engineer advises earth loop test failure with reading greater than 200ohms. Advises Electrical inspection. Electrical engineer reconnects earth clamp at gas meter that was disconnected and fixes supplementary bonding to pipes at boiler. Advises earth continuity greater than 200 Mohms and earth loop impedance 0.60ohms. Gas engineer returns and advises earth loop test failure again within boiler. Isolates boiler at fused spur and diagnoses fault with Ignition PCB. Now awaiting replacement part, but boiler still condemned for having poor earth. Whose advice is incorrect? Could the Ignition PCB problem beihng causing the failed earth loop test? Would appreciate any advice as have children of 1 and 3 and have no central heating or hot water.
