This relates to questions I have been asked by the installer. I have suggested the inverter connects to the garage DB which is fed from the house by SWA. The installer has asked for details of existing loads in the garage to confirm the cable has capacity for the "extra" current from the inverter.
But to my mind, unless there's something weird about AC then surely generated current will be subtracted from the load current rather than added to it. For example let's say stuff in the garage is drawing 10A and solar generates 5A then the cable would be carrying the difference, 5A, from the house. If solar generates 21A then the cable would be carrying 11A but in this case back to the house.
Does that sound correct? Just wanted to sanity check, i dont want to come across as a smart arse to the installers especially if I'm wrong. But also when the actual technically knowledgeable people turn up to install, I don't want to find then walking off because I've not filled in the questionnaire correctly.
