Hi
I am installing a solar power system with a standby generator both going into a battery bank. An attached inverted is providing me with 230V AC which I need to run to a location about 300 m distant. The cable to the load will be buried SWA, and will carry a maximum current of 10A, but usually less than 1A.
Can you recommend cable size, and ground fault protection configuration for this setup?
