Accenta 8 alarm
14 Jan 2011
Nottingham
Hi
All of a sudden my alarm will not set, on the control panel one of zones will not set. It a PIR and if i omit that PIR the alarm will set, i have tried changing the PIR and still, it is the same, What could the fault be ???
You physically changed the PIR?
Followed the same colours?
If so it seems to be a cable fault.
Test with a multi meter.
Hi Yes i have changed it using same colours, but still doe snot work, even wehn i do th ewalk test, the Led di dnot come on, how can it be cable, it was woeking one day and then next day it would not set
hi i have checked all the fuzes , and all seem ok
OK, so you have removed each fuse and checked it with your meter, haven't you? ( Looking at them does not do it. )
As you have done what I said, connect your meter across the 12v supply at the PIR, if it's not there .........
yes i have removed al fuses, they are ok, but there is no 12v supply to PIR
I assume you have put the fuses back?
What control panel do you have, knowing that might be a help to us in helping you?
Had any new carpets laid, dropped anything heavy on the floor that might have damaged a cable, dog a dog that chews, the list goes on?
I might not be back again tonight, it's Friday you know, things to do, places to go.
Got a test meter...............use it.
Looking at a fuse does not mean it works.
Recheck the fuse (s).
Remove all cables from the power to detectors then test voltage there.
put back one at a time, if the fuse blows there is the issue.
Its basic stuff, check and test, check and test.
If this is too difficult for you engage an engineer for 30 mins.
He/she will diagnose this in a few mins and offer a solution.
