What's the standard solution for putting in access points on 32 and 40mm waste pipes? Can you buy access bends for these sizes of pipe or is it done another way?
Push fit/compression doesnt need access, worst case scenario, pull it apart to clean it out.
If using solvent weld waste, replace bends with a Tee as necessary, then fit an access plug in unused socket of Tee. Plug can then be unscrewed should access be required.
