Accurately measuring high frequency AC.
  • Thread starter Thread starter BQW
  • Start date Start date
BQW
15 Apr 2008
Isle of Wight
Hope some one can help with this one, strictly not a DIY job, but I have been asked at work to measure a 8 Khz, 650 Volt RMS AC voltage to a accuracy of plus or minus 5 volts.
Tried several good quality digital meters but they don't appear to respond accurately to AC of that frequency.
Did intend to try a Scope with a special HV attenuation probe, but I don't think a difference of 5 volts will not show up as any measurable size difference on the trace.
Does any one know of a meter or type of meter that would do the job (not yet tried my old AVO 8)
Any comments and help appreciated.
... I have been asked at work to measure a 8 Khz, 650 Volt RMS AC voltage to a accuracy of plus or minus 5 volts. ... Tried several good quality digital meters but they don't appear to respond accurately to AC of that frequency.
Even up-market DVMs usually seem specified only up to 500Hz or 1kHz.
I would imagine you're probably right - although it obviously depends upon how much 'offset' ('Y-shift') the scope allows.
Does any one know of a meter or type of meter that would do the job (not yet tried my old AVO:cool:
Have you considered doing what your 'old AVO' would do - i.e. rectifying the AC and then using a standard DVM to measure the peak DC? I wouldn't imagine that you would need too much of a capacitor to achieve adequate smoothing at 8kHz.
Kind Regards, John
My 34410A is specified to work in that frequency range. Pretty sure the newer 34465A has similar specifications, and if you don't want to buy they can be easily hired from the usual suspects.
I have been informed by some one knowledgeable, that the old style AVO 8 Meter with its copper oxide rectifier is accurate up to 100Khz.
So its now time to blow the dust of my old AVO 8.
Thanks for the replies, I did find some suggested circuits and methods using a DMM on the net, but the maths needed to calculate the % of accuracy was beyond me and the small financial recompense I receive.
As Implied, that doesn't surprise me.
However, no matter how theoretically accurate it is, are you not going to have a potential problem with anything that has an analogue display - since, presumably using something like a 1000V range, a difference of 5V is probablyalmost as small as one could hope to distinguish visually, even with the mirrored scale of an AVO (even the pointer is probably about "1 volt wide")? ...
On the other hand, if you 'did the rectifying yourself', you could then use a digital meter as the measuring device, thereby removing that problem.
Kind Regards, John
