I had a problem with the valve on my heating system. Simply it stopped working. I could move the manual lever with alot of effort to manual so I assumed it was worn out. It is located on the exit side of my pump, one exit to the hot water tank the other the heating (rads).
The cover is marked
acl Appliance Components Ltd motortrol
Volts 240
Hz 50
Watts 10
Maximum 200 PSI system Pressure
I can't read all of the part number but what I can see is the last part
14 30L0
It has three wires and the diagramme on the metal cover reads like this:
Brown +
Power
Blue -
OPT. GREEN Earth (using the earth sign)
The plumber fitted a new vavle which I have put in the manual position. This lets me have hot water only. He has now told me the valve he fitted is wrong and as the old one had three wires and the new one has five I thought this was the case (I'm no plumber but I am a mechanical engineer).
So I've thought the best idea is for me to get the new valve so he can fit it.
Does any one know the replacement name and part number? I assume it's a Drayfos (?) I got that far on the web but no further.
I need help here. Thanks in advance.
The cover is marked
Volts 240
Hz 50
Watts 10
14 30L0
Brown +
Power
Blue -
