aco drain corners
14 Mar 2009
Surrey
might be a silly question but can you go around corners without having to buy these ?
they cost twice as much as 1m of aco
http://www.toolstation.com/shop/Roo...orner+Unit+Plastic+Grating/d250/sd3170/p99860
[/img]
Granted they are expensive, but very much worth it at the end of the day.....after all, you'll only do this job once.
John :)
you can just cut mitres but they then won't clip together but it shouldn't matter if you set them well on a bed of concrete. A bit of silicone between the join in the bases wouldn't hurt either.
cheers
i found storm drain sell the same type drains as aco and the quad connectors are only £6
:P
Hi im just wondering if you ever got your aco corner sorted as im having same trouble and dont want to pay fortunes for these aco quad corners if another manufacturers will fit
