Aco drain
16 Jan 2022
Morning,
Not sure this is the right place to post this question !
I'm just in the process of doing my aco drains, Is there a way to overlap ( side by side ) a aco drain? I've got a brick pillar in the way but it isn't enough corner to put a corner to get around it , I can't move the acos further out as there's a narrow path but also slopes towards the house so needs to be against the house wall plus a motar joint. Any ideas or help would be greatly appreciated. I'd say the aco would need to over lap 100-150mm
Jake
I would do what you suggest, and if needed , cast some sharp sand/cement beside what you have to channel the water between them.
