I am looking for the best low-cost solution (if that's not a contradiction) to improve the acoustic insulation between the kitchen and our bedroom above. Any suggestions?
At the moment there is just 12.5mm plasterboard (taped and filled, not skimmed with plaster) the joists (175x75mm) and then 22mm t&g chipboard, plus underlay and carpet above. A particular problem is that the kitchen was dry-lined, so even relatively small noises like an appliance being plugged in or taps running sound quite loud in the bedroom above.
I am reasonably experienced DIY-er but would prefer if possible to avoid re-doing the ceiling as I would need to get in help to do that. As far as I can see the chipboard is screwed down, not sure if the t&g is glued but anyway I am happy to replace the floor with thicker chipboard if that's a good idea or just take it up to get insulation between the joists. The downlights are not acoustic variety so I am assuming I will replace those. What else should I do to minimise the noise going upwards?
