Anyone had any experience with the ACV cylinders, how do they compare with other. I hear the re-heat time is much quicker?
Much cheaper and far faster reheat using a direct cylinder, a plate heat exchanger and a bronze pump. Also condensing is guaranteed for 90% plus of reheat.
theres nothing wrong with a "sludge bucket" keep you in work for years![]()
Why are you always pushing the thermal stores. Ive never come accross a plumber that prefers one over an unvented indirect cylinder, wouldnt touch Gledhill with a bargepoll
Page 11 of the link is what BB was describing.
http://www.stokvisboilers.com/Brochure/EconoPlate C Series.pdf
Used more on commercial systems but can easily be applied to domestic cylinders.
I only know one plumber out of about half a dozen in my area who sets his systems up this way. Very highly sought after plumber and his pipework is perfection, but you know when you have him in your gaffe as he ain't cheap.
Don't start Drivel off on b****y Sludge Buckets again please![]()
I take on board your comments... but answer this. Why do unvented cylinders outsell the heat bank (thermal store) type cylinders by about 50 to 1 ?
And the unvented's tend to be slightly more exensive, as you have already mentioned. Why are they not in every house, the unvented cylinders are so much more popular.
Look at this thread "Heat Banks" on how an integrated heat bank is put together. An amateur DIYer figured it out and bought one to order. He put to shame the so-called professionals on this forum, even doing so tests on how it performed, noting return temperatures that promoted extensive condensing efficiencies, which was impressive (Not to be disparaging, however it could be improved even further that is how efficient they can be, however
