I have a Glow-worm back boiler which is tapped for gravity feed by 4 connections.The central heating has a twin pipe flow system & separate return.I believe this complex set up is because of the shape of the bungalow & the remote location of the pump (15 mtrs from boiler).It works extremely well & the boiler is bullet proof.The hot cylinder (roof space) is compromised & needs replacing.At this point sourcing a gravity cylinder is difficult as most suppliers only stock cylinders for fully pumped systems.I aware that there will be a clamour to upgrade the entire system to conform to modern standards, but am unwilling to change a complex but very effective set up just because of a defective cylinder.Maybe in the future.I like the idea used by JohnD (posted Jan 2010).I would like to place a 2-port valve & pump on the return side of the coil immediately after leaving the cylinder & controlled by a cylinder stat.The cold feed/exp is a T at the flow input to the cylinder.I realise that some balancing of the flow will be required, hopefully at the pump gate valves.My question is: Does my thinking fit with those that have successfully achieved this & do i need an additional programmer to control this set up independently of the central heating pump.
Ron
Ron
