Add insulation to after fit bay window
3 Oct 2012
Good afternoon,
The previous owners of our 1960s bungalow ripped out the original front windows and added bay windows. Unfortunately they ommited to install any insulation. Consequently the bays get extremely cold. When I replace the windows I may consider going back to a flat fit. But that won't be for a few years.
In the meantime can I add some insulation to help matters? There is a lip of about 22mm under the sill. Could I install some 20mm eps board under the base of the bay window? And also install some thinner insulation boarding on the internal part of the bay. Top and bottom. Would this be likely to make a difference?
Grateful for any comments.
definitely go for foil-faced pir like celotex or kingspan over eps if you've only got 20mm to play with mate, way better thermal value for the thickness. wedge it tight under the sill lip and foam any gaps with low-expansion foam before capping it off with trim so draughts don't bypass it. doing the inside with thin insulated plasterboard will make a massive difference to the room temp straight away.
