Adding a radiator to a curent CH system
11 Jan 2010
Stirlingshire
hi folks
since you appear to be fairly knowledgeable persons around here... :D
just looking for some advice and or comments to confirm or confuse my own thoughts...
am looking to fit a small radiator in our fridge of a kitchen,
our CH combi is situated a couple of meters away from where i intend to put the radiator and the main pipes run directly down from it to the under floor area where it is then fed and returned to the radiators by manifolds.
Is there any reason why i cant just tap into the feed and return lines just below the CH Combi rather than from the under floor manifolds?
If this is ok? does any one know of a self cutting connection that could be used to tap into these pipes rather than draining the whole system and putting in Tee's?
thanks in advance :?
