Adding a wired room thermostat to a Worcester Combi?
4 Sep 2005
Leicestershire
I have moved into a house that has a Worcester 35CDi (non-Greenstar) Combi boiler installed.
The programmer on it is a sigle channel mechanical jobby.
You can buy a RF Digistat programmer for the boiler but it is over £150.
I would just like the boiler to run off a wired room thermostat - a Drayton Digistat 1 for example.
Does anybody know if it is possible to wire a room thermostat directly into this boiler?
Thanks,
Dave
Yes it is possible and straight forward . Have a look on the worcester site and you will be able to bring up the installation instructions which will tell tell you how to do it
Thanks for the tip namsag, but I have had a good search on the Worcester site and cannot locate the instructions.
Would you be able to post a link please?
Thanks for your time and input.
Dave
On the home page click on litrerature on top banner ,then click on gas boilers . And a list of boilers appear scroll down past the greenstar range an the thirty fiveCDi rsf is there at the bottom click on this then click on installation and servicing
