Hello all,
I am looking to add an ensuite to my house and will be replacing the old boiler at the same time.
Current heating equipment:
Potterton Neatheat 10-16
25L Cold water storage in attic
Hot water cylinder in airing cupboard
Bath/Mixer tap – attached to shower head (gravity)
15mm cold feed into the house
22mm gas feed (I think)
Proposed ensuite
1700*900 shower cubicle
Sink
Tolet
Towel Rad (will re-use current rad feeds)
What I would like to be able todo is have two showers running at the same time or even just over lap each other when turning off or on.
I looked at the mega flows, but because I only have a 15mm cold feed into the house, I think this is out of the question.
I have read somewhere that you can get a Combi Boiler with stored heat.
Does this mean that I can have one shower running off the combi and another shower running off the stored heat (maybe with a pump).
Is this possible?
If not what would you recommend?
Many thanks
James
Proposed ensuite
Sink
Tolet
Is this possible?
Many thanks
James
