The house we moved into recently, has very good underfloor heating on the, solid ground floor but we have found that the first floor has no insulation fitted at all below the pipework. There is a foil 'spreader' above the pipes, which seems to be big sheets of galvanised metal laid on top of the joists before the boards were fixed and not in contact withe the pipes.
Very little heat rises through the floor and is hardly worth having the heating running upstairs.
Do you know of a system of adding insulation under the pipework that does not involve removing the ceiling below? Maybe some sort of foam filler.
Ron
Ron
