Hi
I want to add a radiator in my conservatory. I have a Biasi condensing combi boiler which is 12 months old and more than capable.
The closest existing radiator to the conservatory is about 6ft away in the dinning room. From what I can see the flow & return pipes to this radiator
are 15mm in the floorboards but are reduced down to 10mm on the drop down the wall to the radiator.
I was wondering if I could tee off the flow & return pipes at the back of this radiator (10mm pipes) or will I have to go back to the 15mm in the floorboards. ie would teeing into the 10mm pipes be too much of a flow resriction.
Also I believe I have to put isolator values before the pipes exit the house.
