I want to provide power for a table lamp in my lounge. There is no convenient location for adding a spur to the existing ring main. However there is a light switch for an outside light. This light switch is at the end of a radial circuit and all the lights in the house have been wired with the light switch acting as the junction box, ie most switches have 3 cables to them: power in, power out and light. This particular switch at the end of the circuit just has two cables: power in and light. There are currently only 5 100W lights on the circuit.
Clearly there would be no problem with extending this circuit if I wanted to fit another outside light - I would just run another power out cable to the next switch and light. However could I fit a standard power socket on the end instead to be able to plug in my lamp?
I have tried to do this as described above and most of the time it has been OK but occasionally it is tripping the circuit. What have I done wrong and is there a way of fixing it.
