Additional Rad question
28 Nov 2010
Hi all. I have a conventional boiler in my garage, open vented, fully pumped y plan. 2 x 22mm flow and return leave boiler and travel to a/c where open vent, cold feed, pump then plan are. Pretty standard stuff. Now above the garage and boiler is an ensuite I had put in a couple of years back and it’s chuffing freezing...big towel rad in there gets nice and hot but 2 x external walls, above a garage etc make the room in the winter, cold, particularly when exiting the shower !. Is there anything stopping me adding an extra rad directly off the flow and return at the boiler below ? I understand every time the boiler comes on, so will this rad but will fit a trv for summer when Just water is heating..is this ok ? I just have in my mind that the hot water cylinder should be the last connection but as I’m happy with this rad on with just water does it matter ?? Thanks in advance
Slightly aside from your question but are you sure the insulation is there? External walls or not, and towel rails do have poor heat loss, but a new room would be easy to heat with a towel rail that isn't covered in towels.
We do have the correct insulation however half of the ensuite hangs over the garage which then has a lean to up against the ensuite wall. Wind blows at the garage it seems more than anywhere else pushing the cold into the ensuite. Which to be fair could be better insulated from the garage side. Maybe that’s an option, just wanted to sense check the rad option as well. Cheers
If cold is blowing in there must be a problem with your air barrier. Insulation should work pretty much the same in windy conditions if the builder did it properly
