I've just had a wood floor put in on concrete, and needed to use a two part epoxy resin dpm to seal the floor and stop moisture affecting the wood. Left a section near the door to tile later with machine made 6" quarries, and now need advice on what kind of adhesive to use to stick them to the epoxy. The resin has set smooth and shiny like it's meant to, and I didn't think ahead and blind it with quartz or sand.
Is this just a matter of giving the dpm a harsh sanding then using an off the shelf adhesive for non-porous tiles, eg porcelain?
Any advice gratefully received.
