I've got a Whirlpool ADP4501/5 that had a problem with the water level switch, hopefully fixed now, It also had the drain pump clogged up thats hopefully cleared now
The problem is I dont know how to use the machine.
The instructions are worse than useless, there is NOTHING on the programs, or which one is which, they arent even mentioned.
How do I turn it on?> Just select a program and press start? or do I have to hold the button in?
How do I reset the machine? It had the error with 4 flashes which hopefully I've cleared.
At the moment its draining, letting a small bit of warer in and then after what seems like forever the green light slowly flashes at a rate of appx once a second.
I'm not even sure I've turned it on right.
