Advice about FCU?
26 Mar 2006
Hi was wondering if someone could offer a little help?
At the moment i have a spur double socket running from a ring double, i done this last year.
Now what i need to do is run a heater in the room but keep the double in place aswell as isolate the heater if required, is this what i need to do?
DS (ring) -> S/FCU (13a) -> DS
now is i used a switched fcu so i can isolate the heater will this also switch off the DS supply aswell?
So would this be better
DS (ring) -> FCU (13a) -> DS -> S/FCU
The Switched FCU will then isolate the heater or is there a easier way to do this?
The only problem is the heater will be placed where the FCU will be so if i do put the Switched FCU at the end i will need to run more cable.
The ideal solution is to put both the double socket and FCU on the ring, but if thats not possible, then
sounds ok as long as the DS is not expected to supply heavy loads
