ADVICE - Ferroli Optima 701 Replacement Low Water Pressure switch?
5 Jan 2009
Hi Guys
I am looking for a replacement LPS for an Optima 701 and can NOT find one.
If you look at the diagram/PDF for the boiler it is NOTHING like the drawing (Ref-114), it is actually a big black unit that protrudes forwards (i understand this is just for a better diagram layout).
Does the part still exist as it is switching at 3.6 bar thus the PRV is constantly passing like a tap as i need mains pressure in order to get boiler working, everything else works fine....
https://www.ccha.org.uk/wp-content/uploads/2016/03/Ferroli-Optima_701_Manual.pdf
Cheers
It looks nothing like that unless it has a plastic cover/shroud over it?
It has 4 connections coming from it 2 are used as in diagram and wired to the PCB (N/O Contacts) and the other two are just spades, prob N/C..Not sure what they are for...
I will see if i can get a pic tomorrow mate..
I have stuck a gate valve on the fill loop as temp fix and got it 'balanced' as best i can so the PRV is just a dripping now.....
Thanks for replying.
send me a pic of it, it wont be specific to just that boiler and I will send you a link where you can order one
Will do, it looks like there's just a rubber shroud covering the PSwitch.
I think you are correct and it will be a standard 3 pin...
I'll post a pic tomorrow.
