Hi all,
I'm struggling to decide what to do with some rough ground at the side of my house. I need this to be level to be used as a car parking / maintenance space, so my initial thoughts were to use concrete, although I'm unsure if using paving flags would be easier.
The ground is sloped away from the house (to the bottom of the picture) towards the garden. The ground is currently an uneven mix of old concrete and paving slabs. I was originally thinking to break up the ground and build a form, then have a local company come and pour/level the concrete. Apart from sloping for drainage, is there anything else I would need to allow for? There a couple of things I'm not sure about:
1) Can I leave the old concrete underneath, or do I need to do something with it?
2) Would I need to put a form down the house side, then once removed fill with something?
I'm after a relatively cheap solution that I can do pretty quickly. In the future I think I'll either move house or maybe build a garage here.
Thanks in advance
Thanks in advance
