Advice needed for fitting a pump
Does this now mean I need three feeds from the loft tank? (1 for the cold inlet on the pump, 1 for the cylinder and 1 for the non shower cold water?) Or can the 28mm feed supply the cylinder and the cold service?
seperate feed for the other cold ain't a bad idea
the point of the cylinder feed being 28 is to prevent air being drawn in
less restriction on the cold feed
you could use a surrey or warix flange for the hot easier than an essex
raising the tank/s won;t be a bad idea either :wink: View media item 14781 ESSEX FLANGE
View media item 14782SURREY FLANGE
certainly won't hurt and make sure the cylinder connection is clear before you connect up
ie not full of scale etc :wink:
now naff orf
im going to let some nutter draw on me :shock:
OK im half way through this and have come across a problem while trying to install the surrey flange. There appears to be a threaded reducer screwed into the top of the cylinder which is stuck fast. Have tried a spanner up to the point where it felt like the cylinder would bend.
Any ideas, blowtorch? WD40? Or is it easier to forget getting this off and buy an essex flange instead?
Heat and short sharp shocks with a hammer are the answer here.
If the cylinder is foam lagged then be careful with the flame, you may want the connect something to it and heat that instead thermal conduction will heat the joint.
When its hot put your spanner back on and put pressure on it as well as tapping it with mallet, this will crack the joint.
Is the pump going in the airing cupboard?
Hi JayJay
I didnt trust myself with the blowtorch near the foam insulation so used an Essex flange in the end. It was a easier to fit than people were making out. Yes the pump is going in the airing cupboard.
