Advice needed on S.T Monsoon N3.0 Bar Twin water pump
23 Sep 2013
London
Hi all,
I have been having problems with my water pump since I had an electric shower put in last year.
First it kept turning on & off like when you turn the tap on, one day I counted that it did this 40 times in one day! (No leaks from the taps) So I have been turning the pump off from the mains and only turning it on when I need hot water in my kitchen. But now the pump sounds different to how it used to and will sometimes stop mid flow of water running. Sometimes it will not come on when I switch it on from the mains and it makes a humming noise and a burning smell coming from it so I turn it straight off.
I live in a Housing Association property (10yrs) and I had maintenance out today, sods law the pump came on so he says as he see's it here and now it's working, no matter what I have told him it's has been doing for the last year!
Can anyone shed some light on what might be wrong with it please?
Many thanks
I'm afraid to say but when you mention -
then that doesn't bode well :(
That's a case of either the impeller ( the bit that does the pumping) is jamming due to wear or the motor itself is on its last legs
Hi Rob
Thanks for the reply... I know it's on it's last legs but it's proving it to these incompetent maintenance men that know nothing.
