We currently have an electric shower that runs straight off the mains. I'm considering switching to a thermostatic mixer shower instead.
I've got the following set up;
- top floor flat
- a 400x800 Hot water cylinder
- a 600x500x450 Cold water cistern positioned just above the cylinder
- a Stuart Turner Monsoon N3.0 Bar Twin Pump which powers the taps.
- my wife and I spend a combined total of 30 mins in the shower in the morning.
I was considering installing a shower mixer tap to the bath. However, because the capacity of my hot water tank is so paltry and the pump is so powerful, I'm guessing I'm going to run out of hot water extremely quickly.
Note: I wouldn't mind reducing the flow, if the pressure was higher.
I've read that showerheads could hold the answer.
appanretly here are many now designed for about 3 bar which supply only about 10 litres/minute but introduce air into the flow which sort of makes it more volume.
I am guessing that a mixer shower and normal shower head, powered by that the 3.0 pump, is going to push out more like 20 litres per minute. I'm worried that even with the added air, I'm going to run out of hot water too quickly.
Can anyone give me some guidance? Thanks in advance!
- top floor flat
