Advice Needed...
10 May 2009
Cambridgeshire
Hi guys! I'm Darren from Cambs in the UK.
I've recently spent a small future on eight signed & numbered, limited edition art prints & custom framing.
I want to hang them in my bedroom, but the walls are made of plasterboard. Each picture weighs no more than 5kg. My landlord has requested that I don't heavy duty fixings i.e. the metal rawlplugs that expand behind the plasterboard when tightened up, as they can be a nightmare to remove & will cause a lot of mess.
I went to my local art suppliers today & they surgested using two of these double hooks (made by a company called Rektangle) per picture, as one of them alone can hold 5kg:-
I decided to buy a pack of three & see how I got on hanging just the one pic. When I got home, I read on the back of the packet (to see if there were any specific instructions) & it said that I should really be using these plasterboard hooks:-
Now I'm really confused! To me the double hook does look more substantial that the plasterboard hook... HELP!
Any help would be very much appreciated,
Darren
Either will do.
The important thing is, when you hit the nail in, or press the hook in, is to make sure you don't jig it about , as then it will be a loose fixing. Just some light, straight taps to hit it in. With nails, angle then downwards slightly.
Normal plastic wall plugs will do for this job (and lots of others in vertical plasterboard), again as long as the hole has not been jigged about when drilling to widen it and make the plug loose
There are also plastic wall plugs for plasterboard, which do expand at the back, but looks just like any other wall plug, and when you leave, you can knock them through or drill them back out.
If the wall is one were it gets some vibration from doors opening/closing etc, then nails or hooks may work loose over time, so go for a wall plug and screw fixing
