Advice on building a retaining wall
27 Oct 2008
South Tyneside
Hello
I need to build a retaining wall between a new raised lawn and a large garden shed. The wall will be 2 feet high and 20 feet long and I was looking for any advice on doing this?
I haven’t decided on which material to use, I’m open to the idea of breeze block, brick, sleepers, gabion, anything really. My main queries are around the following areas…
How do I ensure the pressure from the new raised lawn doesn’t push the retaining wall over?
Do I need to include some sort of damp proofing between the wall and soil of the raised lawn?
Do I need to worry about drainage from the lawn? (The retaining lawn is only alongside one edge of the square lawn)
A large shed is already in position approximately 18 inches from the lower side of where the wall will be built.
Any advice would be gratefully accepted
Regards
from my experience I've built a good base reinforced concrete with some bars left pointing up/out and used hollow concrete block placed over the bars, and then back filled after with concrete! Trust me, car smacked it and still didnt budge!
damp proofing - for what your doing I personally wouldn't bother.
You could every so often after its all done drill holes to allow water to escape as your doing it over a long distance.
hope it helps!
Your options are In order of cost and roughly in longevity too.
Sleepers
Dry stack retaining walls such as tobermore secura lite or others
Gabions
Full masonary.
2ft is not a big height at all and i would say a well built 9 inch block wall would be up to the job. maybe step the bottom 2 courses out to 13''.
For drainage simply back filling your wall with about a 200mm channel of clean stone and then leaving some weep holes will be plenty. For dry stack or gabions then no weep holes needed.
A masonary wall will need damp proofed usually done with either a sheet of DPM or A liquid DPM painted on. This is done to stop water staining showing through onto the render or brick face.
