Non condensing Vokera Linea plus boiler
I have had a GSR engineer out twice, yesterday and friday. The remit was service/check over and hopefully solve a degree of pressure loss. Unfortunately after doing this and pressurising the expansion vessel my pressure loss problem is WORSE!!! It used to take about ten days drop 1.5 bar with heating on a lot, now literally ten hours.
Yesterday he replaced the safety valve. Still the same. Accessing the back of the property is difficult but today I will try to look, just to see if any sign of water passing or indeed sign of any ongoing water passing. It's an upper flat and to the best of my knowledge no sign of a bad leak/reports from downstairs neighbour.
About 2 years ago I was told the main heat exchanger had a slight leak, this was when I started to become aware the system wasn't holding pressure as it used to. I just lived with it on the assumption it wasn't doing any harm. I remember getting shown the leak by this (different) GSR engineer but actually didn't see what he was talking about. The new engineer said we would soon know if it was the main HE. Is it at all possible this could still be the culprit, or on a non condensing boiler would water be seen, particularly with this extent of pressure loss?
This is starting to feel like an expensive nightmare. I can't believe nor explain the problem becoming worse!
