I'm thinking of fitting Marbrex (Swish) panelling around a new shower bath and have a couple of questions if anyone can help please (Nige F I've seen your posts on this stuff and you rate it highly)...
1. Is it best to fit the panelling before the bath, i.e. bath fits flush to panelling which continues behind, or is it best to fit bath first then fit panels down to bath ?
2. Should a bath seal be used or is it best to fit the panels as close as possible to the bath top then use a bead of silicone ?
3. The panelling will be fitted onto newly plastered walls (one external the other plasterboard stud)...anyone recommend which adhesive to use as I guess I don't need to use battens ?
