Hi there.
So a short time ago I had a builder come and install this door. We had an old wooden door with an arched window above which was lovely to look at but rotting. The builder came and installed his!! (see pictures).. The window arch was removed, replaced with a sheet of PVC and sealed. The mess you see to the left is where our mains cable entered into the house. This has since been moved so the whole thing looks even more unsightly now.
We are hoping to move soon, and so really don't want to have too much excess cost of replacing the whole door with arched window on top. Im looking for some suggestion on how to make this look better. Are arched windows (im sure theres a technical name) available on their own? or would a fresh, piece of PVC be the only real solution here without replacing the whole thing?
The other Im having is that the door is quite draughty. I know its not the best door, but is there some sort of seal I can buy to replace the current one, to create a better seal between door and frame? The draught seems to be coming in the the bottom of the door and top corner, opening side.
Any help or advice would be greatly appreciated. Im not getting the builder back to rectify any of this, as when it was fitted the frame was sealed at the bottom, on the outside....... resulting in the rain pouring into our porch... I rectified that, after getting no response from a number of phone calls to him.. lesson well and truly learnt.
Thanks,
Dougie.
Thanks,
Dougie.
