Can someone direct me to a website that gives you information on what I need to do exactly to insulate my pitched roof. I have 20 sheets of 50mm kingspan to put between the roof rafters. I have recently had a new roof fitted along with vent 3 underfelt. Do I need to install the kingspan between the rafters leaving a small air gap because of my vent 3 felt or does it still need to be 50mm gap. If so once the kingspan is between the rafters do I also need a foil quilt as extra insulation over the top of the rafters as well and then cross battan the foil.
Any advice would be greatly appreciated.
