hi there, i have a question about insulating pitched roof in a midterraced house small house.
at the moment there is no insulation on the roof and loose insulating material between joists in the floor, underneath chipboard.
I'm not sure of the costruction of the roof but by the looks of it there are tiles on the outside laid on the wood boards which are fixed to the rafters. I don't think there is any membrane on the outside of the wood boards but there may very well be. Because I'm not sure I'm assuming there isn't one.
Rafters are 100mm deep and space between rafters is 400mm.
My idea is to fit celotex or kingspan 50mm insulation as per this guide:
http://www.lets-do-diy.com/Projects-and-advice/Lofts/Insulating-the-rafters.aspx
It is not going to be habitable area so I don't think I'm going to plasterboard it but I'd like to create a "warm roof" setup to minimize heat escaping through the roof.
Will 50mm of celotex or kingspan will be enough insulating material and do I need to fix this vapour barrier or is that not required? or maybe its already included in celotex/kingspan sheet?
thanks!
thanks!
