The point is that no SE wants to put anything other than the most nominal horizontal forces into the top of a masonry wall, as masonry doesn't like bending and tends to crack...However, since loose cut raise ceiling roofs generally have some sort of SE calcs backing up the sizes specified its generally assumed that horizontal thrust will also of been included in the calc and designed accordingly. Kind of like what tony has included above![]()
Hence the reason most SEs will specify a ridge beam. It just looks like a nice alternative to a ridge beam to me, to allow for a bit of horizontal movement, without having to build the wall out of reinforced concrete! I think 5 or 6mm would not be unreasonable.
So using collars etc.. doesnt help to reduce the horizontal force ?
