- Joined
- 11 Jun 2012
- Messages
- 103
- Reaction score
- 1
- Country
Hi, this isn't a job i plan to DIY, but just after some advice.
all the rooms in our house are generally warm when the central heating is on, the living room though is often pretty cool and never really stays warm.
The room has 2 smallish radiators in, they are both 70cm wide and 58cm high.
The room is 5m x 4.5m
The room does have a large window area with the French doors and windows either side of the doors plus skylight windows above the doors.
Not long after we moved in, we did ask the developer is the wall insulation had definitely been put it as the side of the house that is on the end does feel very cold to touch in the winter, at the time they said it was done but they couldn't really test for how well it was done (but it would have been)
I am guessing the windows is probably where we lose a lot of the warmth but i have always felt the radiators are a bit on the small side as well, so thought it might be best all-around to look into replacing the radiator that’s situated behind the sofa.
I understand the sofa might also suck up a bit of the heat, the top of the radiator is about level with the top of the sofa. there is about a 10cm gap between the sofa and radiator.
The other radiator is actually a bit behind the tv in the corner, not great places for them i guess but where the developer put the radiators is basically where you would naturally put these things.
So i am thinking a bigger radiator might help these issues and keep the room a little warmer but i don't really know what i am best looking at and how do i know it will definitely be better than what i have? I don't really see a model no on the radiators to look them up to compare, but generally if i get a bigger one will it generally be better?
Are the fittings all the same as well, could i just buy any radiator that looks like it will suit?
Excluding the price of the radiator, how much would i expect to pay someone to fit it as well?
If anyone can give me some advice that would be great
James
James
