Advice on tiling corners - trim
17 Dec 2008
Nottingham
Hi all,
a while back i tiled our kitchen, i know the more experienced tiler is likely to laugh at my efforts, but generally the tiles have gone on pretty well.
My main issue, as you can well see below is that when i put the trims on i kind of knew i was bodging it but it was the end of the day and some strange demon in my mind said "you can fix that later!"
So, how SHOULD i have done it? (please don't bother with the "get a pro tiler in" comments)
If i should remove the trims and re-do them fine, i have a multi-tool that will enable me to do that (hopefully).
I've tiled a few walls now and they've ended up looking pretty good, but some haven't needed trims, and it seems that putting the trims on seems to vex me every time.
So, your advise on how best to put this right would be greatly appreciated.
Thanks folks :)
jacko - I've taken pity on you as others have ignored your post.
Use a Stanley knife to slice off the tops of those horizontal trims but take care not to chip the glaze on the tiles; leave the vertical trim in place.
Fill the top edge of the tiles with grout and blend in with your finger to produce a smooth flat finish. Also fill any gaps between the tiles and vertical trim whilst your at it. Leave to harden.
Paint the top edge the same as the wall above.
Jibbs - trouble with that are the sections of new trim which are meant to go behind the tiles ... they couldn't be fitted in without lifting off the top row of tiles or trying to scrape-out about 20+mm behind the top tiles. Many pros would omit the horizontal trim and just fill/paint top edge as per my previous post
The only other option you might have to is to cut the trims to size then cut off the piece that normally goes behind the tile and use clear silicone to stick the edges down.
