Advice please - Baxi Combi 105e
21 Feb 2005
Can anyone help me please!!
My boiler has a slow water drip coming from under the left hand side of the instrument panel??
It has been suggested to me that the hot water valve may need replacing?? This has been quoted as costing 100 pounds??
Does anyone know what it could be or how much it should cost to fix??
Please help!!! :(
Looking for ideas and help because I don't know what it is!
Anyone please?
the drip is coming out below the boiler, about 3 inches from the left at a join under the instrument panel??
Cheers
the drip is running along the base where its falling from aint where its coming from
could be the auto air vent :?:
could be the diverter valve :?:
could be the flow switch :?:
you need to drop the front and have a look
sorry if this is not what you want to hear but we are not mind readers
If you aren't losing pressure on the guage, it more than likely is the front of the dhw diaphragm section. At first baxi would only sell a full valve but now do a dhw diapragm kit that includes the seal.
I think it is also losing pressure slightly as it is normally on or just below 1??
I have no idea on plumber costs...
Is 100 pound an acceptable cost for a plumber to come out and replace a water valve on my boiler please anyone??
And should I be switching it off as there is water coming out of it - all be it a small amount?
undo the two screws on either side of the panel
the large white top cover slides upwards
then the panel drops down
have a look where the water is coming from and post back
100 quid for new divertor is a good price ,even the service kits on these can cost up to 70 quid depending where you get them . But should only need the gland nut replaces as these are the usual sorce of leaks on 105e`s(but you can only get that in a service kit)
Must be BG, always a stuck front door so you have to take the nice man up the back passage for him to fix your boiler.
^^ Think it is this hopefully. A plumber that came out thought the same.
Where's the best place to get one as he says he can only get the full valve!
