Hi All,
I am new to the forum but have ready many posts and am a little confused! I am looking to insulate a timber garden log cabin 16ft x 10ft (walls and ceiling for all year use as a home office). The cladding is relatively thin at around 25mm. In the interior the battoning is only 44mm deep.
My plan:
- Extend interior vertical battons depth by 63mm to create 107mm recess (existing 44mm batton + 63mm studwork) and paint with preservative
- Fit 80mm celotex flush to batton leaving 27mm air gap between celotex and exterior wood cladding
-Staple a thick polythene sheet after celotex to stop moisture passing through
-Add plasterboard
So would look like this on side profile:
Outside wall/23mm air gap/80mm celotex/polythene sheet/plasterboard
Guys please please let me know if you think this would be sufficient and any advice would be much appreciated! For instance I have heard discussions of breathable membranes but dont know what this is or where i would put it! Would polythene sheeting after the celotex and before the plasterboard be sufficient etc?
Please help advice needed!
My plan:
-Add plasterboard
