I am unsure after reading a fair bit, what temperature to set the heating to on my boiler. At the moment the temperature is between 50 and 60. It has taken roughly 1.5 hours to raise the temperature in the house about 3c. If the water is 70c or above it takes about an hour to raise the temp 3c.
Question is, should the temperature of the water be higher so the house heats quicker or is it better to have the lower temperature so that the boiler condenses, although it "should" condense if the water temperature is at 70.
I guess this doesn't make a lot of sense, but really I'm asking is it better to have the CH flow at the higher or lower temperature with regards to efficiency and the amount of time the house is taking to heat up
