I've purchased 45 sheets of 8 by 4 6mm WBP ply to overlay all the floorbaords in my house as the boards are in bad nick.
I've done most of the house, screwing the ply at 30cm centres (probably hire a stapler to make the centres less).
On the receipt I have just noticed it says the ply is not suitable for flooring so after spending ages doing the floors I rang the company to ask about this.
The fellas said it is OK to carpet / vinyl over the ply but not laminate.
The reason being that the big sheets can shrink and distort the laminate. Is this right?
The ply has been in the house for about a month before fitting and will have been laid for a couple of months before final floor coverings.
Should I lift it where I am having laminate? Or should any shrinkage have happened when the two months is up and I can caulk any gaps?
Or could I lay insulation board on top of the ply?
I am loathe to lift as I have a knee op next week so will be out of action and this will set me back but at the same time I don't want to shell out for the flooring for it to look naff.
Any advice would be great cheers.
