AEG washing machine not filling ... help pls!
aus
26 Apr 2009
Kent
Have a 10 yr old AEG Lavamat washing machine. Worked perfectly but has suddenly stopped filling on main wash cycle - it hums, produces a couple of clicks, but just won't fill with water.
If I run a pre wash cycle pre the main, this works perfectly - fills with water, washes, spins, empties etc.
So I'm guessing the water feed is OK - what's good to check next and any clues of how to check (water valve solenoid?)
Many thanks
if the machine is currently working on some cycles but not others then a possible faulty timer / program dial
if it hums check hot supply poss turned off .
