My property has always suffered from bad reception, I believe mostly due to the aerial being loft mounted. In order to finally sort this I used an installer who was recommended to me to put up an external aerial. Some of the things I was told don't ring true so I thought I'd double check things.
The installer put up a high gain Master plug Aero16-mp Aerial (which he kept saying was really really good as it was gold! and you can't buy in the shops which I know is wrong as b&q sell them), the aerial comes with the boom split into 2, you bolt the 2 parts together to make the full length. The installer didn't connect the boom extension (saying that it isn't needed and makes the aerial too heavy for the post it's mounted on, it would need a 3/4inch steel post for the extension), he even binned the extension (which I have retrieved). The installation instructions which I retrieved from the bin has no mention of only using half of the boom length under any circumstances.
The reception is better than it was on the loft aerial, though analogue is snowy and some digital channels break up. He said he wasn't worried about analogue as it was being switched off soon and the digital channels were operating on half power at the moment so that would improve later!
My humax shows quality as 100% and strength as 60% (at least on one channel I didn't check all), the feed is split by an unpowered wideband splitter he put in the loft to support 3 tvs. He told me that one of the cables feeding one of the tvs was poor quality because it wasn't double screened (i'd never had problems with it and even he agreed that if it works then fine). I noticed that he had cut off the loft end of this cable and spliced another bit of cable onto it which had an f connector on, I was a bit suspicias about this as he hid the join between the cables under the loft insulation, I only realised something was strange because the "cheap" cable was white but there were no white cables going into the splitter.
I checked on a website which said that in my area I should fit an amplified high gain aerial.
I'm 15 miles away from my transmitter and wondering if I would be better off going up and fitting the extension myself plus making sure it's alligned. Since the signal strength is low, I can only assume that if adding the extra bit of boom increases the strength (which is what he said but also said it would be too powerful) would improve the strength going to each tv?
I assume the snowy analogue is wrong and the aerial may need alligning?
