adding cable to aerial
21 Jul 2009
Yorkshire
i bought a new house which had 3 aerial sockets points. i paid for a workman to fit an aerial in my loft but he said he could only find 2 cables up there. i was recently up in loft and have found the third cable. what do you suggest i use to connect it to the aerial?
How are the other 2 cables connected to the aerial?
If they are just twisted together and pushed into the aerial connection box then you need to find a better aerial installer and clean up the muck from his horse :LOL:
Something like this Clicky would do the trick.
Take one lead from the aerial into the splitter and connect the other downleads to the outputs using screw on F connectors
How to connect F Connectors
Twisting together multiple coax cables can cause problems with ghosting and will drop the signal level
