Aggh - cut through Damp Proof Membrane - Solutions?
3 Nov 2006
Herefordshire
Hi All
I've just done something pretty stupid - I was cutting away the expansion gap foam around the edges of the screed in our extension when I accidentally cut about a 20cm slice into the damp proof membrane - Does anyone have any solutions to seal this slice up?
Agreed with the silicone, there won't be a huge water pressure as it's not underground but it can get very wet if there's nowhere else for the water to go.
Thank you! I am going to try a repair patch with DP8005 scotch weld, with silicone also.. I’ll report results for benefit of others.
