I'm not sure if I'm in the right place but hopefully someone can help.?
I have just purchased an electric outboard motor so I now need a battery to run it.
The motor is rated at 12v 35 AH although I believe this is on full power so the AH usage will be lower as it will be used on a lower setting so let's say 30AH average
So I would like a battery to run this for around 3 hours so is it as simple as getting a 90AH battery ?
But from what I have been reading on the Internet a battery shouldn't be completely discharged.
And also should a deep cycle leasure battery be used as some say leasure batteries are not really true deep cycle batteries .
Would I be better to get say two 60AH batteries and strap them together is there any benifit of doing this ?
And lastly my battery charger is rated at 4 amps so would this still carge a high amp hour battery or would I need a better charger or is it just a case that it would take longer to reach full carge?
Sorry for all the questions but it all getting a bit confusing hopefully I'm in the right place to find someone with the answers .
Many thanks
Many thanks
